joshhancock Member J Join Date Jun 2007 Location knoxville,tn Posts 3 Jun 1, 2007 #1 my computer died and i am trying to get a windows 2000 machine to communicate with plc 5/15 help?. it worked fine on my 98 machine. Last edited: Jun 1, 2007
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,342 Jun 1, 2007 #2 Maybe the card got zapped together with the PC. Normally a PKTX card has no problem to operate on a newer PC. It just need the plug-and-play driver for the correct operating system. The plug-and-play driver can be found on the RSLinx CD.
joshhancock Member OP J Join Date Jun 2007 Location knoxville,tn Posts 3 Jun 1, 2007 #3 1784 card windows says it is functioning
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 Jun 1, 2007 #4 I believe there is a special driver for windows 2000. Been awhile, though...try the knowledgebase at ab.com. EDIT: nevermind...the newer driver appears to work on 2k and newer as Jesper said. Have you checked the node number assigned to the card to avoid a conflict with your PLC(s)? Does the driver in RSLinx show to be "Running"? Last edited: Jun 1, 2007
joshhancock Member OP J Join Date Jun 2007 Location knoxville,tn Posts 3 Jun 1, 2007 #5 the driver shows error. i have plc at node 50 ,pc at node 0
allscott Member Join Date Jul 2004 Posts 1,332 Jun 1, 2007 #6 Have you tried stopping the driver and then starting it again in Linx, restarting the computer?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Jun 1, 2007 #7 Can you post a picture of your RSLinx configuration (i.e)
kevin91172 Member K Join Date Feb 2007 Location NEEDVILLE,TEXAS Posts 48 Jun 1, 2007 #8 Just had that Problem.Make sure the computer the driver is on has the right station address.
kevin91172 Member K Join Date Feb 2007 Location NEEDVILLE,TEXAS Posts 48 Jun 1, 2007 #9 You might try this.
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Jun 1, 2007 #10 kevin91172 said: You might try this. Click to expand... That PDF is making me dizzy. And when all else fails http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1784-um527_-en-p.pdf Last edited: Jun 1, 2007
