PLC 5/20 and 5/40
jcp
Feb 2010
Multan
369
Hello Experts;
Good day. I face a problem that the programme is wash from the PLC 5/20 while internal battery is found ok and there is no indication or alarm of the backup battery.
Please help me what are the possible reasons and how i fix it?
Regards
I've seen this serveral times...
I hope that you have a back-up of the program..
How to fix this, I've never fixed it, just reloaded the program, and run!
Goodluck..
Check ground. Make sure all inductive loads have surge protection. And install a UPS and
surge protection for the PLC's power. The UPS installation worked for me.
Hello Mickey;
The power of the PLC 5/20 is supplying by the battery charger. If mains fails its enegise.
I will check the surge detector on the power supply of the PLC. Thanks for the idea.
But can you help me or give me any video tutorials or book in which i read the PLC 5/20 or 5/40 programming, How to install the software if it is washed, How to edit the values how to read and write data, how install the firmware i.e programming structure. I have RSLogix 5.0 version 7.4 i am new one with this.
do u have any wire configration pin to pin to make the serial communication with Laptop have rslogix 5 to plc 5/20 and 5/40.
Please guide me?
Regards
Guys,
do you have the version 7.4 software you can send??? i have a license but not that version. i only have version 8. thanks,
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
159
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
92
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
92
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
62
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
100
