PLC-5 Block Transfers
toont
Sep 2014
Den Bosch
56
Hi!
I have a general question about Block Transfers. If, say, you want to use I/O 10-17 for the transfers, but also for normal I/O communication, how do you know which I/O is used by the Block Transfers?
I know the first output byte in the configured rack is used as a BT status byte, but is other I/O also used by the BT's?
Block transfers use the low byte of the discrete I/O memory word for a given RIO Group, both Input and Output.
So if you have a device at Rack 1, Group 0 then the addresses I:010/00-07 and O:010/00-07 will be reserved for block transfer use.
Addresses I:010/10-17 and O:010/10-17 should be available for general purpose I/O functions.
Are you using a block transfer module inside an actual A-B 1771 series chassis, or a module that emulates a RIO adapter ?
Hi guy. well im having a hard time figuring out how to make a numeric entry in an already made PV program but i've never worked with scanners and...
2,761
I have several "smart" PLC-5 modules (Analog ins and outs, etc) in a RIO remote rack that I need to communicate with via block transfers. From...
1,883
I have to make some changes to an existing older system that has a PLC5 and a PanelView 1400e that communicates via RIO. I need to figure out how...
1,961
Does anyone know of a counter block (either PLC or PAC) that allows configuration of the input signal, such that it can be set to count up/down on...
717
Good Evening , I need to convert a PLC 2/17 ( RS Logix 5 ) over to a CompactLogix 1769-L33ER . I took notice in the RS Logix 5 program that...
2,087
