PLC-5 MSG to Logix 5000 conversion FES
Adam303
Aug 2009
Chicago
587
Hi friends. I have a FES refrigeration system that we want to be able Read and write to, using a MSG instructions. The FES system utilizes a ComMENT protocol. The host (AB PLC) communicates with the FES Gateway’s RS-232 port via AB DF1. I have found some information about how the protocol should be configured to talk to AB DF1, via PLC 5. The issue is that I have never used PLC-5 before and I’m in need to interpret the following MSG instruction in PLC-5 to Logix 5000 L61 controller.
The info shows how the MSG instruction must be configured in PLC-5:
Command: PLC-3 Word Range Read / Write or PLC-5 Typed Read / Write
PLC-5 Data Table Address: target Integer file for data
Size in Elements: Length of read/write up to 120 words
Local/Remote: Local
Local Node Address: Node ID (in octal) of micro panel
Destination D.T. Address: “$Nxx:yy” from ComMENT Network Protocol
Port Number: 0
How can I interpret the above to place in a MSG instruction using Logix 5000.
Thanks for your help.
Hello: Working on a program that needs to read some data from other Rockwell PLCs. Every second my program sends "CIP Data Table Read" command and...
30
6,964
Hello all, I have a MicroLogix 1100 Series B that I am trying to read data from and into a PLC-5/20 Series D Rev A. I assume this is...
3,696
Hi, I am trying to set up 2 msg instructions to read data from a PLC 5/30 into a controllogix L55. The PLC 5 is on a data highway+ with two...
5,013
I am trying to read data from a PLC-5 in my ControlLogix program over Ethernet. I keep getting a connection failure. I followed this procedure...
20,769
I've got a ControlLogix L61 messaging to a PLC 5/40 via ethernet. The message instruction gives an error code which seems appropriate when the...
5,433
