PLC-5 Partial Download Experience?
Flopro
Sep 2004
So Cal
120
Hi Everyone,
I'm working on a PLC-5 program offline that I've modified several files on - adding rungs or branches to rungs. No data table creation or expansion nor COMM channel changes etc. Only rung additions and edits.
I've always had the ability to download entire programs with most clients or had a limited number of edits so online editing wasn't much of a hassle. However, this PLC-5 is DH+ and I'm connected through a CLGX Gateway via Ethernet to a DH+ network so the online latency is severe.
I would like to use the Partial Download feature in RSLogix 5 (Ver. 8) but have never used it before. I am gun shy since this PLC-5 controls the U.V. Lamps on channels performing the final disinfectant on a 31MGD effluent stream. Faulting or unexpectedly shutting down the process creates an event that requires reports being sent to the State Water Resources Board as a violation as well as the EPA/Fish & Game folks because of a sucker fish habitat and that isn't pretty. This would only be a Partial Download of the 5 modified "Program Files" (subroutines) and selected within the Partial Download setup tabs.
I called A-B Tech Support but there's no one there with any experience on the PLC-5 Platform that could help me out with any insight into a Partial Download. The Help Files are short on any depth. So, since I'm a daily visitor and always find great bits of information from others experiences for many years here on PLCS.net; I thought the community might be helpful when it comes to advice or pitfalls to be aware of when using the Partial Download feature in RSLogix 5. If worse comes to worse, I may just begin performing online edits to accomplish the program modification. That's the best A-B could suggest since they didn't know how to ensure there wouldn't be a problem in RUN Mode with a Partial Download.
Any insight will be much appreciated.
Thanks.
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
22
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
58
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
125
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
54
