Plc 5 scp
James_Newman
Mar 2020
Nottingham
Hi
I have a PLC 5/40E which passes speeds to a number of machines via rio.
Currently there is no scaling and the machines use look up tables for different speeds. These values are different for each machine.
I would like to add a SCP for each machine so I can get a units per minute sent to each machine to get some kind off usable values.
I know there is no SCP instruction with in the 5/40E
Does any one have an example of the logic needed to do this.
If you do a search (see Search above) for [scaling ladder formula] on this forum (use the [search entire posts] option), there will be plenty of hits.
http://www.plctalk.net/qanda/showthread.php?t=15069 is one of them; pay particular attention to the plots by Ron Beaufort.
That may not address exactly your particular application, so if that is not enough, ping here again.
How would you aaproach duplicating the Scale with Parameters command in another plc like EzAutomation Touch PLC of which they do not have any...
4,253
48
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
73
281
