leversole
I have been searching and searching for a solution to a seemingly simple problem...I cannot believe I am the only one to need such a solution, maybe I am not searching using the correct key words?
Anyhow, we run Control Logix PLCs with Wonderware as the HMI...what I want to do is create a trend using data in a PLC array tag...for example, I would have 100 reals in the PLC, I want to show them as the Y values in a trend, sounds simple but I cannot find any way to do this. I would even go with some sort of activeX control in a Wonderware window to accomplish this?
Anyone have a solution?
Thanks in advance
LE
Thanks in advance
LE
