PLC-based Christmas lights/displays?
Typically, a PLC is a poor choice to use for complex lighting control and synchronization. Most folk that you see with the seriously impressive displays use something like a Light-O-Rama controller and its software. Most commercial lighting controllers are fully waterproof, handle very high loads, and run much tighter timing then can be done with an inexpensive PLC.
I was looking at using the light-o-rama setup to see if it could be used as a PLC input to drive a multiplexed output setup
maybe next year too busy this one.
I'm using a Moeller Easy, just as a time clock, to turn the lights on and off. I did program a momentary/toggle button, so I can turn them on manually to test/change bulbs.
Thanks - I hadn't heard of that product. Sounds like an ideal solution!
Actually, I'm pretty much a '60s guy when it comes to Christmas light preferences, so for now I'll probably be sticking with my steady-burning incandescent C7 strings, but the capabilities of that controller sure are tempting!
I am trying to use tag based alarms in Studio 5000. It seems really great at making alarms automatic. I have a few alarms that require...
1,062
I got a problem concerning the change of coins from a vending machine plc based, i use the rs logic starter lite with Rs emulate 500 along with...
2,084
Dear Members, I am new to S5 series PLC, In one of my application, I need to communicate S5 6ES5942-7UA12/ or S5 6ES5941-7UA12 PLC with HMI(PC...
2,200
How can I get a rough estimate of how much memory I will need for a controller if the code is not written yet, but I know how much I/O it will be...
3,404
Greeting, I am doing some investigations on which driver(s) support tag based addressing (eg. Pump001_Running) rather than DB or Modbus based...
3,746
