kamenges
Mike-
I understand that you recommended the surge suppresion. And I also understand that you can put together protection for less money than the Sola unit costs that is just as effective. But I'm in Ron's camp on this, especially for the 'casual', one-time user.
I don't know what you use for an internal engineering rate for pricing. But I would suspect the OEM average is about $100/hr. This means anything over 2 hours of time on this and the Sola unit is cheaper. Like I said above, if you will use this all the time and you can justify buying bulk on all the components so you don't have to order them every time AND you can spread your development and learing time over multiple projects then it may make sense to roll your own. But if you are only going to do this once I would say go off the shelf.
Another downfall of engineering evaluation is many of us don't properly cost-account for our time, me included. Peter Nachtway often brings this up with motion control. People look at a $3000 motion controller and get sticker shock. But how many of us could embed motion controller functionality in ANY platform in under 30 hours? Using the OEM cost model I tossed out above, that's what you would have to do. Now, if you could reuse the stuff you developed just once, you cut your per-unit cost in half. So if you do ANYTHING multiple times its inherent cost decreases.
Some might say I'm comparing apples and oranges, but its more like sheds and houses. My two examples are only different scales of the same issue. If you sting enough of the small items together the costs add up.
Keith
Keith
