showshocka
How is it that I was successful in adding a downstream PLC controller to my upstream PLC Ethernet devices (no errors, I can see the downstream controller's info in properties / "Module info" tab) but when I go to set the downstream PLC up for MSG I do not see it listed? In my upstream PLC in the General tab of the downstream PLC listed, it has the local Ethernet address (xx.xx.xx.xx) the network all the building's PLCs talk on, and in the Internet protocol tab it says the downstream PLC "IP Address in physical module does not match address in general properties (192.168.1.20). Let me remind you all, this upstream PLC also has a physical address that is different from the general tab and other PLCs on the building's network are talking to it ans sees this and it's listed in their MSG instructions. How is it I am not seeing this downstream PLC when I try to set up for MSG when I can see all the info on it in my connected Ethernet devices? Thank you.
