One device has to be the Modbus master. The other device must be a Modbus Slave. I don't know what a roborealm is but it's unlikely that it is a Modbus master. Could be, but usually the PLC or a PC or a control system is the master and field devices are slaves.
Each has to communicate on a common hardware link. Your mention of Modbus TCP infers that the common hardware link will be ethernet. Does each device have a port capable of Modbus communications? (Just because there's an ethernet port, doesn't mean that the Modbus protocol is supported).
Modbus just gets data from one device to another. It doesn't DO anything with the data. If you want to Do something with the data, then you need software or firmware or programming what you already have to get make some use of the data transferred via Modbus.
Data in a slave is put into Modbus registers. Most field devices provide a map (list) of the register addresses, what data each register contains. and the data format for the data therein. Some slaves need to be configured or programmed to specify which data is placed internally into Modbus registers for access by a Modbus master. Depends on the device.
A sample communication is the Modbus master sending a packet of bytes that the slave decodes as
- attention, Slave number 5,
- perform function code 03 (provide data in your holding registers)
- starting at Modbus register address decimal (4)0065, where the numeral 4 is understood as the memory area for the 03 function code, but is not included in the message itself.
- provide data from 8 contiguous registers, where a register is understood to be 16 bits (two bytes)
- the CRC (cyclic redundancy check) value is xx, so check to make sure there aren't any extra, missing or flipped bits.
The slave's decoded reply looks like:
- this reply is from slave 5
- I've executed function code 03
- this message has 16 data bytes (contents of 8, two byte registers)
- first register value HIGH is XX (hex), first register value LOW is yy (hex), 2nd register HIGH value, 2nd register LOW value, etc for the required number of registers/bytes.
- CRC value
Chipkin's manual if pretty good:
Modbus for Field Technicians
www.chipkin.com/files/liz/MODBUS_2010Nov12.pdf
