Plc Communication
VAIBHAVCV
Guest
V
HI
I AM FACING A PROBLEM
I AM NOT ABLE CONNECT MY LAPTOP TO PLC TO WORK ONLINE AND TO CHANGES
IN OFFIT WORKS .BUT ONLINE TIS SHOWS NO COMMUNICATION ERROR
WHAT COULD BE THE REASON
rta53 said:
A stuck CAPS key perhaps?
Oddly enough, it was worked just fine while filling in the 'subject line'... :confused:
Vaibhavcv, er, I mean VAIBHAVCV,
You might get better results if you clue us in on the brand of PLC you have... :unsure:
beerchug
-Eric
In no particular order, here are some possibilities:
Wrong cable
Broken wire in cable
COM port in laptop being used by some other application
Incorrect IP address
Incorrect port parameters
Trying to connect RS232 laptop to RS422 PLC
Bad or incorrectly configured interface card in laptop
We can be more helpful if you tell us what brand of PLC and what software package you're using, as well as whether you're trying to communicate through the serial port, via ethernet, or some other interface card in the laptop.
163
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
180
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
96
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
114
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
155
