JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,342 Nov 7, 2011 #16 OK, I'll rephrase it to that it is an Intel Atom-based PLC. Anyway, how much does it cost ?
paraffin power Member Join Date Aug 2002 Location Manchester Posts 527 Nov 7, 2011 #17 Depending on the number of axes you want to control, about 4000-5000 euro. There's 16, 32 and 64 axis versions. All processors have Ethernet/IP and EtherCAT built-in. If you're not using servos, however, then it may not be the best option.
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,698 Nov 7, 2011 #18 I take it the code is compiled to run on this kit ?
