PLC Digital inputs & Analog Inputs Signal
Ones_Zeros
Feb 2014
at work
367
Hello,
I was wondering if you guys could help explain to me how the
wiring and signal on Digital and Analog inputs/outputs run from the PLC to the end device.
I'm wanting to learn how this process works and alot of
times when I set this up in the SCADA software, the wiring is already completed.
Say on a digital input/output wiring does 24v run on the positive wire going to the device and neutral back to PLC?
also for the Analog input/output wiring, how does the signal run from the PLC to the end device and back to PLC. For example to open a valve or to read a analog pressure?
Sorry for dumb questions, I dont just want to set this up in the software, i want to fully understand the wiring scheme and how the signal runs.
Maybe you guys can explain it in simple terms
thanks again
Most PLCs are 24v for digital logic, will a Digital input card detect a 12v (automotive) signal as a 1 Looking to do some work on a...
4,303
Hello all, I am a recent graduate at my first job tasked with a PLC project. I need to control a linear actuator given feedback from several...
2,158
I Posted through this Thread... http://www.plctalk.net/qanda/showthread.php?t=70318
2,373
Dear All, We have made the age old mistake of laying all cables (DI/DO/AI/AO/ VFD Power & Control/ DOL Power & Control) in one cable trey. I know...
5,315
Hi group! Repeatedly found answers to some questions in the PLC's programming world, now I decided to ask the question directly) Now I am...
22
4,246
