plc Electrospindle
twin oaks
Jul 2005
MO.
Im having a proble with a error im getting a lot. Its telling me my plc electrospindle cooler check the automatic safety switch, the flow switch of the coolant circuit and the thermal cutout on the pump motor. It is kicking the braker alot. I have checked the AMP. and Volts all is of. Could this be that is getting hot. Please help
As much as I would like to go into flyback varistors and capacitor flux, I won't.
Can you give more details, including brand of PLC, model, and CPU module number.
What is your voltage and current on the motor, is it single or three phase, and what is it's horsepower rating.
Are you operating 50 or 60 cycles, or is it through a VFD.
If itis a VFD, do you have an inverter bypass panel on it?
Is it warm, hot, or extremely hot?
What is the current rating on the breaker, and is it a one, two, or three pole.
Do you have a copy of the schematic or plc program that you can list.
Any further information would be of great assistance.
regards.....casey
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
160
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
94
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
92
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
62
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
100
