PLC is ignoring inputs (only sometimes). Kinco CPU506. Help me solve this please
The problem is your programming method. There are no steps, no progress. Other problem source is the using set and reset instructions. Avoid these if it is possibile. Make a state machine, otherwise you just will waste your time with countinous debugging every day.
kindly need to understand why can't upload the plc
50
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
49
245
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
195
