PLC lader timers and counter in S7 300
usman
Oct 2008
UAE
44
Hello friends I start newly plc programing with S7 300 but I dont know how to set and S_CU up counter, can any one help me about that with all settings.
Thanks and regards
USMAN
Selecting the counter an pressing F1 will always give you some kind of help.
If you choose a CU-counter you have the option of a 'box':
on the top you"ll need to write the adres of the counter; exaple C0
on the left you'll have the input's:
CU: count-up signal example; I0.0
S: set signal; the counter will go to a presetvalue
PV: counter presetvalue example: C#5
R: reset, making the counter zero
on the right you'll have the output's:
Q: '0' if the countervalue is zero, '1' if the countervalue is not equal to zero
CV: countervalue as integer
CV_BCD: countervalue as BCD
Yeah the all I do same like that but its not stop on the same value many time I try it set same counter its count also but not stop on the CV velue. If you can give total advice to me.
Thanks and regards
Usman
The CV is only a preset-value. The counter will start again with this value instead of a previous value. Nothing more, nothing less.
Personally I like a CD-counter with the preset-value the value I want to count to. Then I will count down; example 5,4,3,2,1,0
I will will use the counter like this:
start C1 motor
Motor will be '1' if 'start' and C1 are '1'. C1 is '1' if it is still counting to zero.
When C1 = '0' , I will need to set the counter again to it's presetvalue at least if you want to start the motor again.
When you will use a CU-counter you will need to make a comparison if the countervalue is equal to a certain value on wich you want to make an action or stop an action.
47
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
67
280
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
198
