Plc Manufacturers please
I hope this doesn't overwhelm you, but here is a link to many PLC manufacturers...
http://www.plcs.net/chapters/links.htm
What is it you are specifically looking to do?
If you are new to PLCs, which it appears to be, you will want to consider your needs first before selecting a PLC. Not all PLCs are created equal...which is true for the manufacturers as well.
We have done the complaining about delivery times in a couple of other threads, I am not trying to repeat that. I am trying to find out if any...
22
5,914
67
53
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
76
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
50
