I'm curious if PC based control is growing or is stagnant
BobB said:Hopefully shrinking!
I notice they mention PACs - most modern PLCs can do what these devices can do because of extended/expanded functions etc from what I can see. There has been a move in Ozz for some consultants to try and use SCADA and standard PLCs for BMS systems to get away from the prorietary stuff that has been traditionally used for this. The mechanical people have a tendancy to want to remove warranty unless thier preferred BMS contractor does the work. I have been there trying to fight it on several projects. When warranty removal is brought up, the clients tend to go back to the traditional method.
Correct.OZZ=Aussie=Australia
Under the context used I think BMS is Building Management Systems, Bob can correct that if necessary.
I'm thinking that Bob was referring to standard PCs running emulation software to do a PLCs job.
Clearly off the shelf PCs weren't designed for that type of application.
remove warranty
By contrast the ControlLogix system can be efficiently applied to not only machine logic, but the much wider disciplines of motion control and process control at the same time, while allowing a much greater openess and flexibility.
Don't believe everything your read.Part of this I do not understand, PAC's did not technically come into existence until 2001. The main differences between PAC and PLC is PAC's are suppose to offer a more open architecture that allows less concern for compatibility issues.
