PLC Newbe looking for direction
Michael_MSN
Jun 2008
N.E. Ohio
HI All, I've got a Direct Locic DD-05DD with an F0-04AD-2 4 analog input module. Have a 0-10V current transducer connected to input 1 on the analog card. I've only been studying PLC programming for a week or so and havnt done any memory register manipulation yet. Woud someone ming giving me some pointers on how to program an analog device. Havnt been able to find much online. essentially all i want to do with it right now is print the actual current reading out of port2 as a text string.
Thanks in advance
Mike
Michael_MSN,
To get the data out of the module you need to have this rung of logic. You will also have to cycle the power on the plc.
You need to get this working first. Then you can tackle the comm port.
Here is the analog manual online
http://web5.automationdirect.com/static/manuals/d0optionsm/ch5.pdf
kindly need to understand why can't upload the plc
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
225
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
193
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
44
