Hello everyone, so I have an issue with a plc on a crane not wanting to stay online for longer than 5 or so minutes. And sometimes not even wanting to connect at all once it takes itself offline. The Plc is a GE PACsystems RX3i, with 12 slots, with a CPU315 in slot 3. On this same network is a bunch of different Ethernet devices that all eventually plug into an “N-Tron” Ethernet switch module.. I have an HMI also on this network that seems to be communicating just fine, and not going out. I’m trying to connect to the plc and make it stay online through a pc which is also plugged into the Ethernet switch. I’ve changed Ethernet cords, and did some other testing and everything seems to be okay, but I can’t get the plc to stay online through the pc at all times and as mentioned above sometimes it doesn’t even want to connect after taking itself offline.. I’m using Proficy machine edition program through my pc also. any help is very much appreciated!! I will be glad to give someone some more information on it also!!
