Plc omron cqm1-h cpu21
aleziv
Dec 2009
belgrade
Hello all,
This is my first post on the forum and I hope somebody could help me, in factory we have one system for nitrating tools (furnace), and heart of the system is PLC OMRON CQM1-H CPU21,system existed since 2005,ok now problem is: before two days furnace stopped, message on the Scada PC was,cominication problem with PLC,all led diodes on the PLC turned off(RUN,ERR/ALM,INH,PRPHL) except diode COMM which is blinked, any outputs doesn’t work, from inputs we are have only auto/man (form double switch on the door).
We can’t to communicate with PLC over CX Programmer, we mistrust the CPU doesn’t work.
Is somebody having similar problem (according to symptoms) and what is reasons for that.
Thank you in advance.
try disconnecting all wires from the PLC check and make sure the power supply is working also I've had a problem with the backplane of the PLC that caused a ground short. This may be a strong possible cause of why the PLC is not powering up. Also one quirk on Cx-pragrammer is opening the correct commport from when it was originally programmed at. Check what comm port your curently using goto the project tree right click the processor symbol and goto change and set the correct comport there rather than use auto connect
Thank you gays for suggestions, we still not sure what is happened, processor unit we have sent to a Omron service and we will see.
Thank you anyway
Hi; I have a DUPONT brand machine having OMRON PLC CQM1-CPU21-E. I have CX Programmer installed in my Laptop having W1indow10. I want to go...
3,612
I'm using an Omron CQM1 plc which is connected to an IPS01 power supply which is connected to a DA021 analog output module. All I want to do is...
1,936
HELLO I HAVE A PROPLEME WITH CPU41 IT'S LOCKED WHAT I MUST DOING? THANK'S :site:
2,324
Hi, I'm trying to convert some Omron code into SLC500 logic. This is from an old Sysmac CQM1 Omron plc. I can understand most of it, except for...
7,420
I would like to connect a touch panel from Siemens (TP27 10 inch) to a Omron CQM1 PLC. I have tried to make a cable for it but it is not...
4,837
