PLC (pick and place ) keyence
imEG
Jul 2010
Tampines
Hi, I'm doing a program but i seem to have some problem.
hope that someone out here would be able to help me out.
First of all here's the scenario. there 3 cylinder.. name A, B and C
there's a start and stop bottom, a sensor and a vacuum.
when start button is press, Cylinder A which has a vacuum and a sensor attach to it. It will fully extended to pick the seed up. if the sensor did not sense any object that is been pick, it will repeat the Cylinder A extend and retract process again till the object is been pick then it will carry on by moving Cylinder B and C together to a point where it stop and fully extend Cylinder C to drop the seed and retract back. then Cylinder B and C retracts back to the original position
remarks this process is continues.
C+ | C- | A+/B+ | C+ | C- | A-/B-
A is using 3/2 way valve with single solenoid spring return
both B and C is using 5/3 way valve with double solenoid.
there's 2 reed switch for every cylinder.
for the Cylinder A i have a problem doing a repeat cycle for the sensing of the seed if its not been pick.
Hi everyone Can anyone help me to understand the ladder logic of pick and place system of ITS PLC atg edition ? thank you
2,246
hi everyone, I'm new with plc, and am trying to connect cpu 313c with pc via MPI usb cable. Plc is set to run a FESTO pick and place station. I...
4,340
Okay, So I need to move a Z axis to pick and then place 4 tiers of product. The pick is always at same location, the place will have 4 different...
2,969
Hello, this is my first post here so please be gentle. :) How could I pick the perfect generation of a PLC? For e.g when I pick a PLC for a new...
3,174
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
25
