georgia boy
- Join Date
- May 2005
- Posts
- 14
hi guys
i am kind of new to print desighn standards . my application is i have a micrologix 1000 plc and i have a program that opens air solenoid vales on a conveyor system . when we have problems with these valves they have liquid tight all the back to the control panel so the easiest place to test the coil is the control panel . the L1 lead of any coil is easy to find because the address is marked on the terminal block . but the L2 side of any coil is marked L2 on the terminal block . with there being so many it is hard to find which leads to test. how can i mark these terminal blocks so that you can find each L2 wire and know which valve it goes to . but also still know it is L2 . also should my terminal blocks which contain plc output wires be labeled with the plc address or the wire refrence number from the print. if wire refrence how do you distingish between them . the print i have has 1 for L1 and 2 for L2 and these could be going anywhere i need to know how to use and label terminal blocks correctly
thanks in advance
gb
thanks in advance
gb
