PLC Program HELP EASY512 DC-RC
mellman17
Jul 2015
kansas city missouri
I have to program the Easy512 DC-RC to a Linak control unit CB20 and two LA34 actuators. I am having trouble programming the PLC to get the actuators to go in and out continuously, only one - way movement with one rung on the PLC switching the outputs between Q1 and Q2 only seems to work. Also, it only works if either the input is NC or the output is NC. The wiring setup is as follows: Using a 9 din plug with lead wires exposed at the end; I have a red common wire wired to port 1 of the Q1 (on the Easy512 plc) orange wire for simultaneous in function of the actuators. The common wire is jump wired to pin 1 of Q2 with a green wire for simultaneous out function of the actuators. The din plug is plugged into a DJB box and into the CB20control unit port 1 (where the hand pendant goes) and the actuators are coming out of the CB20 base channel 1 and channel 2. I got this wiring from the manufacturer of the control box. I used the interlocking method to program the actuators and I am unable to get it to work. If anyone could help with code that I can understand (explained) I would greatly appreciate it.
Thank you,
Mell
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
104
I will be designing an automated hydrostatic system. The system on paper works like this, a plc like the click will get information from an hmi...
227
43,459
Hello. I am working on a PLC program that needs to check input 1 after timer two is complete to see if a valve can close or not. Below is the flow...
2,845
Hello all, I am currently doing a project for a client. Where they want a custom claw machine built and programmed. The ask is for there to be...
2,280
Hey everyone, I'm currently in my last year of high school and I have to automate a scorebord for a foosball table using 4 optical sensors (sender...
38
6,370
