PLC Program that will run Christmas lights
Damon8561
Guest
D
Hi Can someone please tell me how to write a RSLogix 500 PLC program that will decrement and increment or use a bit shift that will allow the Christmas lights to change lighting sequences. I need at least 20 minutes worth of PLC Ladder logic. I have a micrologic 1000 processor. THank you for your time.
Get the manuals for the 1000 first: http://www.ab.com/manuals/cp/#mlogix
Try offering more details about what you are going to be using and what you need it to do.
1. Which ML do you have?
2. How many lights or group of lights are there?
3. What kind of sequence are you looking to create?
First thing to do is write down specifically what you need the program to do in the order you need it done. Study the instruction set to determine which instruction(s) seem best suited for the application. Make an attempt but keep it simple using 3 or 4 outputs.
BUT !!!
But real carefull, I've seen nice PLC destroyed by christmass lights sequences.
If you are using relay output and you make them go ON and OFF to often the PLC will be soon dead.
Hello everyone!!, I may be asking a newbie question, but I want to be sure of that. Can I run a PLC program directly from the SD card? I mean, I...
197
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,059
I had bought a used PLC before but I had to return it. Once in a while its run mode shut off momentarily. I had the PLC on my desk. (No I/Os...
22
5,397
Hi, I want to run a .HTML/.asp file from within B&R compact PLC. The files I am talking about are stored on CF root of PLC. I want to call these...
2,736
