PLC Shutting Down.
thetech
Jun 2010
Louisiana
18
I'm working with a Automation Direct (P3-550) - 16in - 16 out. I have a input that sends an output to a relay to turn on a Operator Interface (Red Lion). The problem is when the Operator Interface tries to turn on the PLC shuts down and does a reboot. I'm using a good 10amp 24volt power supply, so lack of power is not the problem. What I did to fix it was put a capacitor across the P3-550 power supply inputs and the problem went away.
My question is what should be the correct value of capacitor should I use?
And is this the right step to fix this problem?
TheTech
A reaonably good power supply should have capacity to avoid such. You may want to review the supply connections as you may have a voltage drop at some point. you don't want to daisy chain the supplies, rather bring them seperately off the supply for each device.
I do have the PLC and the Operator Interface daisy chained. But I figured with #14 wire and 10amp supply I would not have any trouble. I ques I was wrong. I'll run a [FONT=&quot]separate wire for each.
Thanks for the tip.
That was really quick.
[/FONT]
Another thing to remember is that while 14 ga Cu will handle 15 amp at 120 vac, you need to derate it by at least 50 % to 7 amps at 12 vdc...and over kill on the main power wiring can go a long way to 'fix' design boo-boo's...:mad:
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
178
112
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
96
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
65
