Tom Jenkins
Another vote for "interlock" as the description. I've done it direct PLC to PLC in the past when I wanted a fault in one machine to cause the standby to start. I used relay outputs on one PLC direct to the inputs on another PLC.
I don't see any need special need to use a relay for this connection. It really isn't any different than connecting the PLC input to an external switch. If the environment or voltage mismatch doesn't justify an interposing relay for all field switches it doesn't justify it for this kind of connection.
