PLC vs PepperL-Fuchs Laser Sensor
We do apx 70 inch wide web at 800 FPM with multiple micro-epsilons. Not sure the OP's actual need, but we don't need the full 70 inch stitched together. Just strategic samples across the width. Coverage of the 70" is probably 50". About 15K worth of hardware, not including an existing CLX.
It is expensive!
Compactlogix 5480! window 10 IOT Enterpise.
Windows 10 IoT Enterprise is a version of Windows 10 that is designed for use on Internet of Things (IoT) devices. It is compatible with the .NET Framework, and you can use it to develop and run .NET applications
In order to do so, the DLL files need to be compiled specifically for ARM chips.
I'd be borrowing one from a rockwell distributor to test before splashing the cash.
Maybe not, looks like rockwell went with Intel, my other searches on that OS only revealed ARM.
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
225
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
193
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
44
255
