Plc
yaashry
Dec 2012
petaling jaya
Hi! its regarding Remote control wiring in Conveyor system. This system has 7 Car body carrier moving around on the Conveyor. Each one carrier has individual PLC control panel and communicate with a Station Main PLC Panel. They used very old 3rd party Remote control system (Daifuku RBC) to send and receive I/O signals. For the transmission signal cable from master to slave, it is via "Current Collector Conductor".
We are going to upgrade this system due to obsolete model and high maintenance cost. (Mitsubishi 'A series to Q series)
My question is, can I use CC Link cable wiring via "Current Collector Conductor". Do you think CC Link Error will occur when the Carrier moves around?
Kindly give me some solution.
Thank you
164
102
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
92
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
62
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
101
