PeterW
I could do with a little help understanding how the addresses are linked.
I'm having to check and probably modify an existing system which is consists of a redundant PLC5 system interfacing to a number of Flexlogic units (the Flexlogic is used purely as serial interface modules to other machines).
The interface is ControlNet via MSG instructions in the PLC5.
I can open the MSG and see as the pictures below:
But I cannot see how this data actually gets to the correct data in the Flexlogix. I know where it goes, a DINT[3] TAG.
The MSG indicates N10:0 as the destination address, I presume this is a dummy, as no TAG in the Flex has even been called N10:0.
I am missing the RSNetworx ControlNet project file that is linked in the CPU properties, does this have additional info that will link the data direct to the correct TAG?
I have other more modern projects doing the same thing (using ControlLogix PLC's) and of course the TAGS in the Flex are marked as Consumed in these. In the PLC5 project they are not as the PLC5 cannot produce.
Can someone gime me a pointer of where the link is firmed up, is it in that missing file?
