Kent Hostetler
- Join Date
- Jan 2005
- Posts
- 84
Three times now I have had my PLC5-80E have a major fault with program loss while doing things with the connected ethernet network.
First time, in 2003, I don't think it was a coincidence that this happened at the same time I installed RSLinx and began to configure it. The ethernet LED was blinking code "7", which AB said means "overflow trap vector instruction" to Allen Bradley's internal technicians. No in fo beyond that - AB said replace PLC if it happens again (was in service 24 months).
Never had a problem until last two faults in the last month. Both happened while powering on or off a new CompactLogix processor in another panel.
Some info:
Some info:
- Ethernet is run with fiber, with Hirschmann fiber hubs to convert to cat5
- 1st fault happened while configuring RsLinx on my laptop 6 years ago. Code was 7.
- 2nd and 3rd faults happened last month when I was powering down a control panel that's using a CompactLogic processor. Code both times were 69 (seems like a 69, or 6 and 9, or 9 and 6, or 96. Anyway, a 6 and nine were flashing as 6>short pause>9>longer pause>repeat. AB tech connect discussion - AB said there is no code 69.
- Not 100% sure if fault occurred while powing down or up the CompactLogix, but almost certain it occurs when powering down.
- Two messages exist b/w the PLCs
- Network between them is PLC5>cat5>into Hirschmann fiber hub cat5 port > out of another cat5 port on hub > Belden EthernetIP cable > CompactLogix ethernet port.
