PLC5 Messaging Across A Router
jimdavie
Nov 2008
Wishaw
I have PLC5's at our main site and at a remote pumping station. Routing is set up across ISDN to allow me to access the remote PLC's from the main site SCADA LAN. I can ping the remote LAN, interrogate the remote PLC's and access a remote SCADA using remote desktop or VNC but I can't get PLC5 messaging to work between the two sites to fire some alarn klaxons and bring in some analogue values I'm interested in. Before I increased the message connect timeout and message reply timeout settings in the PLC on the main site I was getting a comms timeout error in the MSG block but now the MSG block sits enabled but doesn't complete the read, no errors are generated. Any ideas ?
Cheers
Jim
First make sure that the Default Gateway address in the PLC-5E itself is the correct address of the router that leads to the remote network.
PING and HTTP and RDP are well-known protocols that most firewalls and routers handle gracefully. The PLC-5 MSG instructions operate on TCP Ports 2222 (native PLC5) and 44818 (Multi-Hop Mode).
Try the TCPING utility to make sure that those two ports are being handled correctly by your router.
If neither of those approaches shows useful information, you're going to need to find a mirror port to sniff the Ethernet data stream.
Thanks Ken,
The main site PLC gateway address is different but I'm going to need to wait for a plant shutdown to change it. Let you know how I get on.
Jim
Hey guys, I'm trying to set up messaging between two PLC 5 processors that are on Data Highway, but I'm having a difficult time finding any...
1,468
I understand that the sidecars don't support CIP, so I don't think I can initiate a message from the CLX in this case. (I tried PLC5 Typed Read...
4,112
I am trying to read data from a PLC-5 in my ControlLogix program over Ethernet. I keep getting a connection failure. I have configured many...
1,953
Hi all, we have a plc5 messaging to a slc500 via wireless network. the wireless unit went down and it took a week to replace it. its now up and...
1,771
I'm using an Allen Bradley PLC5/30 PLC with a Moxa EIP-3170 DF1-EIP converter plugged into the serial port for communications. On the machine I...
1,829
