PLC's ADC fluctuate when vibratory feeder run
Kyldera
Jul 2017
Kedah
Hi all
I have a Panasonic AFP-X C60T PLC which has been added a 2 channel ADC cassette AFP-X AD2. Both channel are hooked up to 2 weighing indicator 4-20mA analog output respectively. The indicators output weight reading. I use the analogue current signal for the ADC. On the same panel together with the PLC and the 2 indicators, there are 2 vibratory feeder controller. The vibratory feeder unit is located around 1 meter from the panel. The controller is hooked up to a vibratory feeder unit each. The ADC reading is displayed via a touchscreen. The reading of the ADC is as per the indicator displayed weight, until when i run any of the vibrator, thats when the reading for both the ADC channel starts to fluctuate. From my observation the fluctuation range for channel 1 is smaller than channel 2. Channel 1 fluctuation is around +/- 15grams while channel 2 is around +/- 50grams. The indicator seems does not affected by the problem, the reading is stable. I cannot say for sure if the analogue output of the indicator is stable or not since i dont have an oscilloscope. PLC, the 2 controller incoming supply is 240VAC and indicator incoming supply is 24VDC. I have tried to use Yunpen YD10T4 emi filter to clean up the incoming supply of the PLC but the problem still occur.Can any one help me to identify the cause of the fluctuation and what is the remedy?
Hello Sir, I am new to the PLC & starting to understand it. I have some background in electronics. I now know how the files like 'INTEGER...
6,681
Dear my Friend, Any body can help me..... I have new problem with the air pressure. I used Huba sensor for measure air velocity. In my program the...
5,283
Does anyone know of a way to find out which memory locations correspond to a certain I/O address in Modicon's RLL? I'm mating an Automation...
8,843
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
70
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
43
