Please Help Urgent!
Buddha
May 2005
21
CAN ANYONE UNDERSTAND THIS COMMAND, I DO BUT JUST WANT TO SEE IF OTHERS CAN SO I CAN TALK ABOUT IT AND ASK QUESTIONS,HERE GOES NOTHIN (U MIGHT WANT TO DRAW THE LADDER DIAGRAM):
LDI 402
OUT 450
K 10
LD 450
OUT 451
K 10
LD 450
OR 474
ANI 451
OUT 474
LD 406
OR 475
ANI 411
OUT 475
LD 474
OR 475
OUT 431
END
What PLC and what software you use?
This looks a lot like Mitsubishi but the device types are missing (X, Y, T, M, ...)
I inserted them the best I could and it turns out like five rungs:
LDI M402 OUT T450 K10 (if not M402 run timer T450 with preset 10 or 1.0 sec.)
LD T450 OUT T451 K10 (if T450 run another timer etc.)
LD T450 OR M474 ANI M451 OUT M474
LD M406 OR M475 ANI M411 OUT M475
LD M474 OR M475 OUT M431
But before I waste my breath (clicks) on reply, maybe it's time for you to provide SOME info, don't you think?
Ye Sits The Mitsubishi F Series, What Is Suppose To Happen Is That As X402 Is Normally Closed The Lamp Y431 Will Come On In 10 Seconds Then Go Off Again 10 Seconds Later. But When Push Button X406 Is Pressed The Automatic Way Of Outputting Y431 Is Over Ridden And Y431 Will Come On And Stay On (not Going Off, The Reset Button 411 Turns Off The Output Y431 When Switched. Hope This Helps.
Ok, let's see. After scratching my head over this
one, i guess this is what you wanted.
Please check it out.
X402 T450 K100
T450 T451 K100
X406 T450 T451 Y431
X406 X411 |
Y431 |
I used to have a brown book for all the F1 addresses, but alas - I think it has been filed under 'rubbish'
So I tried wracking my brain, but as you get older the FIFO stack in there gets shorter and they must have gone into the overflow stack by now.
I do seem to remember though that the addresses are one contiguous lump (lump?) without prefix of X or M etc. Or at least if you are using a 'list' only handheld programmer.
So you have to have the address book for the F1 to have a chance otherwise all you can know are the inputs and outputs by looking at the actual PLC and they start at something like 430 431 etc
Goody is correct with regard to absence of prefixes X, Y, M, T, C, etc on F1 plc's. 400 to 427 are inputs, 430 to 447 are outputs, 450 and 451 are timers, but I havn't got a clue what 474 and 475 are. (I had a brown book too and don't know it's current whereabouts).
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,845
Please, I need urgent help from someone who has already used the CDN066 of Mks Instrument. Thank you for someone who want to help me
1,553
Hi Friends I am in need of an urgent help now. We basically built shelters for oil and gas industry. I am doing the fire and gas safety PLC...
2,138
Hi guys' Hopefully all of you are doing well, I tried every where to find standrad symbols to use on P&ID, we have VFD connected to comprossor and...
5,758
I am using a CJ1M CPU12-ETN with 4xADO81-V1, 1xID262, 1xOD212 and 1xOD232. My company kept this PLC switched off in closet for 4 years. Someone a...
1,771
