Plz,could I have an example for user PID use RSlogix5
vungtauso.com
Mar 2011
Viet nam
32
I have an excercise as follows :
+ Level control using PID . (
Tank 1 : 0-200 cm ,The Level sensor : output : 4-20mA
+ using PID control valve (0-100%)
Proportion valve : active pressure : 0-10bar.
Plz,could I have an example .RSP file for user PID use RSlogix5 to study
many thanks
Greetings vungtauso.com ...
and welcome to the forum ...
I've put together a quick "bare bones" PID program for you which should be helpful ... note that I took the basic program file that you sent to me by email and modified it ...
I also made some corrections to the picture file that you sent by email ... (question: why didn't you post that flow chart to the forum also? ... it would be helpful to the other members to see more of how your system is designed) ...
question: are you working on this as a "learning project" just by yourself – or do you have an instructor who has made this assignment? ... also – do you have a working PLC-5 processor that you can use to test this program? ...
I'll try to write more explanation this weekend – but right now I'm tied up getting ready to teach a class which starts on Monday ... see what you can make of the notes I've made on the pictures posted below ... if you have specific questions, post them here in this thread ...
note: please do not send your questions directly to me by email ... when I provide help that way it helps only one person ... when the same questions are asked and answered here on the forum, we have the potential of helping MANY other people who will need the same information in the future ...
I hope that this helps answer your questions ...
  • Huy_PID.zip
  • Huy_PID.pdf
and a few more pictures ... sorry, but I just don't have enough time to explain everything that I've posted ... I'll try to write more when I have a chance ...
hopefully this is a good start ...
Thank to teacher Ron so much,it's make me easy to understand, also i'll try read more about PLC5 at "PLC5 INSTRUCTION REFERENCE MANUAL" .
I have some small question at "attach file"
And also how can i use "a Word,a bit" contains in Interger control block to display in RSview 32 ,
for ex : I want to Setpoint value of valve from 0-100%,or setpoint the value of level in a Tank,or display Lever Bar in RSview 32,Which bit or word i can used for this?
thank full to teacher Ron
take a look at the attached picture and see if it helps you understand the "data files" that you asked about ... also read the following post about the "Block Transfer Mailman" idea ...
http://www.plctalk.net/qanda/showthread.php?p=16077&postcount=3
true story: about 20 years ago I was trying to figure out the same things that you are working on today ... I didn't have an instructor to help me ... I spent several days trying to figure out: "WHAT does the Block Transfer WRITE? ... and ... WHERE does he WRITE it?" ... secret handshake: he does NOT write anything ... he just CARRIES the mail ...
the words WRITE and READ are used ONLY to tell us which way the mail is being carried ... it's actually the PLC PROCESSOR who WRITES or READS the mail ... the Block Transfer instructions just CARRY the mail – in one direction or the other ...
and you got the Process Variable and Control Variables for the PID instruction perfectly correct ...
finally, you didn't answer my questions:
are you working on this as a "learning project" just by yourself – or do you have an instructor who has made this assignment? ... also ...
I'll try to answer your other questions tomorrow ...
ohh..your sample make me very very easy understand.
Last week, I was starting try to learn about PLC5/20, I downloaded many Documents talk about PLC5 and also have many question from you talk about this,
And then, i try to read,and read everyday,
as you know, English is a little obstruct for me, something that i read about PLC5 very easy to learn, but st really hard to understand,
There for,I think the best way pastest to understand is learning from example project + learning from documents,manual....
From example project I can easy recognize the misstake,
This example made by myself, I made this to learning from this,that is the reason why I need an example .
I do this just by myself
In here, there're not PLC5 teacher (I have not an instructor ),I have no Hardware (PLC5,it's so expensive..), no liences software... so...
thank full teacher Ron,
Hi all very new to plc programming all self taught to probably a lot of mistakes background I am a tunneling electrician mostly shot cret lining...
2,692
Dear all, i have a problem in HMI UNIOP ER04, after turn power on appear as attached file pls, what is the reason happened that
1,470
Hi Can I get the programming software and data cable name for allen bredly servo drive which model is 2098-DSD-020x?
2,222
I need some assistance to any Siemens Gurus' who can help me convert the following from STL to Lad. I have tried all the old tricks I can...
4,308
Hi all, I'm new to plctalk (this is my first post actually ). Anyway I am trying to program a micrologix 1400 plc using RS logix 500 . The scope...
6,383
