Plz Give Suggestion for BTW and BTR
aravindhcute
Jan 2010
india
THANKS Sir,
Actually existing program done manufacture he had taken BTW and BTR for Analog Input and outputs for same Rack num(003) only can you explain how it possible.
I am attached the my Analog inputs and outputs BTW and BTR settings
so as per existing logic first analog input module BTR and BTW is taken as (rack003),(group 0,1),(Module-0) and 2nd Analog Input Module for BTR and BTW is taken as(Rack003),(group-2,3),(module-0),3rd Analog Output BTR and BTW is taken as(rack003),(group-4,5),4th Analog Output BTR and BTW is taken as (Rack003)(group-6,7),5th Analog Output Module if i taken Rack003 or else what i can take BTR and BTW is could you give sugestion for that
Hi all very new to plc programming all self taught to probably a lot of mistakes background I am a tunneling electrician mostly shot cret lining...
2,706
Dear all, i have a problem in HMI UNIOP ER04, after turn power on appear as attached file pls, what is the reason happened that
1,472
Hi Can I get the programming software and data cable name for allen bredly servo drive which model is 2098-DSD-020x?
2,225
I need some assistance to any Siemens Gurus' who can help me convert the following from STL to Lad. I have tried all the old tricks I can...
4,312
Hi all, I'm new to plctalk (this is my first post actually ). Anyway I am trying to program a micrologix 1400 plc using RS logix 500 . The scope...
6,397
