pmck card
As Ozee mentions, there is a serial port on the front of the controller. Use a null modem cable to connect from a serial port on your PC to the "Channel 0" port on the controller. If you don't have a real serial port on your PC, most USB/RS232 adapters work just fine.
A more expensive option is the 1784-U2DHP. This is the replacement for the PCMK which is no longer manufactured. The U2DHP is a USB to DH+ adapter. The benefit here is that if your devices are networked, the U2DHP would allow you to plug into and see/program/monitor any of those devices. The serial connection requires you to plug into the specific SLC controller with which you need to communicate. But the U2DHP is very expensive where a null modem cable is not.
OG
Hellooo Just bought me a used pmck/b card off ebay. My old laptop has XP on it and I can't seem to get the right driver installed for it. When I...
2,211
I have ben using an AB 1784-PMCK/B in a Dell Latitude D800 computer. Recently as it was booting it stopped during the startup, as I pulled the...
2,503
I have ran into something this morning I have never seen before. I took over a problem from the 3rd shift guys. We have a line with 9 AB Slick 500...
2,724
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
54
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
66
