Hi All
I have connected a PNOZmulti to an Allen Bradley HMI (PVP 1000) using OPC Kepserver.
I am having some problems in getting the data from the multi controller, I have the data booklet from Pilz defining the different bytes needed for the data, such as the Run, Diag, Fault, IFault and OFault. Problem is when I define the tag in the OPC as a Byte it rejects it as invalid. Has anyone any ideas?
Another problem is I don't know how to setup the alarm messaging in the PV I am able to get the required Tags in the OPC but I cant get them to trigger as a message, if anyone can give me some guidance I would much appreciate it.
Thank you
Thank you
