pnP sensor with IO Card
Lc1
Jan 2014
Uk
59
Hello,
We have the following pressure sensor ( shown in attachment) which has a pnp output. Will this be able to to be wired to a DI card (6DL1131-6BL00-0PH1) in the following way
24V from control panel to pin 1
o v to pin 3
signal to digital input channel eg DI.2+ ( 3) on the card
or will this instrument require an interposing relay as it is a transistor output?
thank you
Dear, I was wondering which one is better to use a PNP sensor or a dry contact sensor, I was checking the inductive sensor from Schneider...
3,754
Ok guys I have a machine down because of a defective prox sensor. The defective prox is a PNP and I don't have a spare, lead time for a new one is...
3,795
Im installing a sensor setup that has only NPN sensors. The sensors count jars that pass by them. The sensors do not control any equipment. The...
8,215
Hello to all, I have a little problem. I have an FP-X C40T panasonic PLC and in the input area i have +24 Vdc. I have NPN optic sensor and I...
14,020
