power flex4
vikas1947
Jun 2011
india
172
i have ac drive ab power flex 4 and signal phase power supply means 1 phase and 1 neutral as present in home now i want to generate three phase can i generate three phase through power flex 4 and run 1 A three phase motar:unsure:
Check you PF4 part number & motor size against the list on page 9 of this data sheet. If your motor's hp is small enough and your PF4 model number is one of the ones that support it, you may be able to run off a single phase source.
i want to know the wiring i have 1.5H.P motor it will run but i don't know the wiring of power flex check the diagram please sir
Part number means ? I just wanted to know how to run three phase motor through drive in the avillabilty of single phase
tnx
thank you very much for the above document and help i will contact you soon when i will do practical jstolaruk:geek:
Dear Vikas,
You have to understand that you will be inputting 230 V to ypur powerflex drive & it will output 3phase 230 V ac. This supply may not be sufficient to drive your motor as in India you would need 3 phase 415 V ac.
Ron
Dear All, I am facing a problem in AB'S frequency drive "POWER FLEX-4" that when I power up the drive a fault occurs "F 012" which...
2,075
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
37
296
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
75
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
48
