Power monitoring unit and control logix
aec
Sep 2011
dubai
162
Hi all,
I need to communicate with 28 Circutor PMU(Power monitoring unit )using a control logix 1756-L61.
Problem is that these PMU uses MODBUS protocol .
By going through the threads I saw PRO SOFT a product used to convert Ethernet to modbus but it needs 1756-ENET which is not available under communication modules in rockwell website for control logix .
How to proceed any suggestion or help please.
Thanks in advance
There 1756-ENET is an old EtherNet/IP module for ControlLogix; the modern 1756-ENBT, 1756-EN2T, and 1756-EN3T can do everything the old one did, but faster.
There are quite a few EtherNet/IP to Modbus bridges on the market, as well as Modbus modules for the ControlLogix chassis.
Are you using RS-232 or RS-485 ? How much data do you need to read, and how fast ?
Hi Ken ,
Thank you for your time and response
I have selected 1756-EN2T.
Can you point some links for me please .
This PMU CVM 96 has both RS 232 and RS 485 so which one would be better for long distance ???
Sorry this is my first communication set up for MODBUS how to determine the Data and speed šŸ“š.
I want to connect 28 PMU from which I will need to get the datas like
Ƙ Busbar voltage (V)
Ƙ Power Factor Bus 1 AND 2
Ƙ Current (A) on feeder
Ƙ Energy (kW) on feeder
Details about the PMU .
http://www.circutor.com/docs/Mn_cvm96ethernet_03.pdf
Thank you :site:
Hi Aec,
You will need to use RS485, as it supports multi-drop.(RS232 is peer to peer and max 15 meters)
The normal RS485 supports up to 31 slaves. However, I recommend you to have 10 slaves/RS485 network. So in your case, you would need 3 coneverters/modbus modules. If the data that you need to read is non-time critical, you can connect all 28 PMU to one RS485 network.
For more detailed info on RS485:
http://en.wikipedia.org/wiki/RS-485
Modbus will allow you to either read one register/command or several registers/command. In your case I would advise to read all in one and that should save some "line time".
I have attached a very basic spread sheet, for line time calculation for Modbus RTU.
//Patrick L
Square D had a group that wanted to develop PLC compatible power monitoring. They worked out of the Cedar Rapids circuit breaker plant - before...
827
Trying to find/understand how best to monitor the current in a three phase circuit with a PLC. Need an analog signal that can be monitored by an...
5,734
I have an AB SLC 5/05 and i want to modify the program to so that i can monitor and record the power being used by the electric motor when its...
1,572
Hi Guys, i have a micrologix 1100 and want to use its analogue input to measure a 12v battery voltage level using resistors. I want to know whats...
7,227
I know this is a PLC forum, but I did a search on my topic and it pulled up an archive from 2006. DickDV seemed to be the most informative on the...
32
16,597
