Power over Ethernet Telephones?
Engineer_UA
Oct 2016
California
43
Greetings,
Is there such a thing as power of ethernet connected phones? I'm thinking CAT6 cables to telephone outlets and connecting telephones with PoE capability to these outlets. CAT6 cable fed from Utility supply.
Thanks,
EE
if you are referring to power over ethernet, yes, they do exist.
BUT !!
you have to have the correct switch to power the phone.
we have cisco 7945 phones through out the plant and use cisco WS-C2960-xxxx single stack and stackable switches to power them.
8,24, and 48 port units. we also have an analog gateway for the analog lines where the 7945's will not survive long.
mixing and matching cisco devices tend to not work well.
I am the local phone programmer at the facility for cisco.
regards,
james
BUT !!
regards,
james
Hi James,
Thank you for the response. You mentioned in the post that the 7945's won't survive long in certain locations. Are you referring to locations which would require the use of more robust telephone units(damp, gaseous, etc. environment)?
Thanks,
EE
Hi all, Im having a weird problem with my panel and i think its the plc causing it but it could be some other component. When i power up my...
2,560
Has anyone seen any POE EIP I/O blocks? I have to ASSuME a company makes an input block. The unit wouldnt be able to do much with any output maybe...
1,604
Totally off topic, but strange observation. I purchased a few cisco ethernet switches off of ebay some years ago. They are part of a home lab...
2,088
I have quick question and any help would be appreciated. We had to replace a power flex 525. So we pulled the parameters from the old one and...
24
6,219
Hi; I have 02nos AB Stratix 2000 (1783-US05T) Ethernet switches having 5 ports. I have a problem that the Power indications of both switches...
1,946
