Power-Up problem with an FM352 CAM card.
userxyz
May 2002
any
2,768
I'm having troubles with a FM352 CAM card.
Every time when they have a power shut-down, they are having a lot of troubles to get the CPU back in RUN Mode.
This is what the CPU says:
They never shut-off the cabinet, so it only happens when there is a Main Power Shut-Down.
After trying a lot of times, they achieve to get the CPU back in Run Mode.
What could be done to this problem ?
In the ab type of plc's, we sometimes have the same problem.
there is a fault over ride at power up bit which we turn on.
this disables fault routine when you immediately power up the processor and allows certain i/o modules to finish powering up before the fault routine for i/o is enabled.
hope this helps,
james
hope this helps,
james
Donno in Siemens PLC where to configure this...
There is no OB interrupt demanding in the diagnostic screen...
Hello
For a differenet module (a M7) the same looking thing happened to me once but I was unable to get the CPU to run. How do you manage to get to CPU run?
What do you do when this problem occurs?
Hello
Hello
Well, they try many times to cut off the power and re-arm. Sometimes the CPU gets in run after trying 15 minuts and sometimes after 2 hours 🔨
So you must understand that this problem is annoying. Such donwtime for a stupid problem. When they start-up the cabinet with the CPU in STOP mode and they reset the switch in RUN after waiting a while, then they achieve to get the CPU to Run (they told me that, I couldn't verify this). So I'm wondering what I can do to prevent this situation... If the FM352 needs more startup time then the CPU, then there must be a simple solution I guess ?
:confused::confused:
What are the startup settings of the CPU,
is 'Startup if preset configuration does not match actual configuration' active?
What is the monitoring time for finished message from module, and for transfer of parameters to modules?
See startup tab in cpu-properties.
Hallow
Hellow,
'Startup if preset configuration does not match actual configuration' is active indeed.
The monitorring times are the default values of 650 and 100.
What can I change to these settings to prevent future problems ?
Thanks,
Regards,
Gerry
Hmm
Okay,
Today I could do some tests and I spoke to the guy who've seen the problem.
We've tried to simulate the problem by shutting down the cabinet, also when the axe is running. We could not reproduce the error.
When the problem happens, this is what he've seen:
The FM352 it's Red led was on. While this led is on, the CPU could not startup. Today the red light is on after a shut down, but it gets off and the CPU is starting normally then.
I think the solution is not to be found in the cpu settings but on the FM352 side....
I've read this in the manual:
Turn on the power on the power supply module.
The red LED SF on the FM 352 is lit briefly and then goes off if the internal module test is OK.
So, my interpretation is that the module sometimes fails the internal module test, after reading this....
Or:
Hardware interrupt lost
Watchdog expired
The FM 352 not configured.
Incorrect FM 352 parameter assignment (only when
parameters assigned with SDB)
No external 24 V auxiliary supply
No front connector
Encoder wire break
Operating error
Absolute encoder frame error
• Incremental encoder pulse missing or zero marker missing
Next time I should also look in the diagnostics of the FM352 I suppose...
Hellow,
Thanks,
Regards,
Gerry
Hi, I am currently trying to test some IO on a ET200S module, I have a constant 24V on all of the Digital Input terminals connected to the...
1,430
846
Hi, I have a power panel 400, its not booting, it stops after booting from hard drive and power user led gets red. thanks
2,059
Hello guys, I have a B&R power panel 400/4pp420-1043-75 with an strange problem. We have just bought a new one but at the starting menu it shows...
11,000
Hello everyone. I have a small problem with a PID block on a SLC 5/05. The PID controls fine when running normally. After starting back up after a...
3,050
