PowerFlew Drive, Remote Control
Caleb_newprog
Aug 2022
Michigan
Hey guys,
Wanted to make a thread so you guys can teach me things! 🔨 Anyways, I have a powerflex 525 that has a control module outside of the panel. The only thing that works on this remote is the stop button for the drive. And I cannot press the start button on the remote to start it up again I have to open the cabinet and press it on the drive itself. How can I fix this? I have attached pictures for reference. Also, I cant even change the Hz on this remote too!
Check the value of P046 - Start Source. I think it needs to be set to 3 for "DSI" when using a remote HIM. I usually use E/IP or digital I/O as the start source, so I could be wrong. Reference the user manual for the drive for the related parameters for start source and speed references.
I'm not certain on this, but I think you need a parameter to enable the remote module. I think a stop will always work for safety reasons.
Hey guys!! Thanks for the answers and yes you guys were correct! I change the source to DSI and that was the fix, but one more question. Can I now change the Hz on this remote or do I still need to do that on the drive parameters itself?
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
286
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
57
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
49
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
56
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
72
