Hello all! This is my first post!
Were I work we have 2 of the exact same machines. Each machine contains 2 PowerFlex 4's Cat# 22A-D4P0N104. They work as expected for the most part. But roughly about every 2 years. We will have one that will not power up as soon as the 480 VAC is applied.
If you disconnect the power for say, 8 hours then turn the power back on. It will take roughly 7 minutes for the troublesome PF 4 to come alive. "Digital display will come on." If you turned off power for 1 hour. It will take about 1 minute for the display to come on.
I realize it's an internal issue, but just wondering if anyone else has had the same issue. Or for the expert's, could we be doing something wrong for say like a bad parameter setting that could be causing the internal failure. Any feedback will be appreciated.
