Powerflex 40 does not fault when motor slows to a stop
Josejalapenos
Jun 2016
Missouri
Hey ya'll, first time posting on here.
For some reason our drive doesn't fault out when the conveyor motor slows to a stop. This causes the rest of the lines to continue as normal, and the hopper continues to fill up until it starts to overflow. I started by checking to see if A125 was set to SVC instead of V/Hz and it was, I know that sometimes when its set to V/Hz the motor can die off and drive will continue to run.
It goes unnoticed until the operator comes by and notices the mess.
Any idea of what might be the problem?
So the basic question you need to clarify is if the VFD is showing a different speed than the motor is running, or if the VFD speed is actually decreasing and the motor is just doing what the drive is telling it to. The way you stated the problem didn't make that clear but it makes a huge difference.
Does anyone know if the Powerflex 525 has a manual mode option like Powerflex 753s do? For the Powerflex 753 I am using a 20-750-ENETR module to...
1,565
Good Morning , This morning we had a overreaction by our maintenance group. They replaced a bunch of 22-COMM -E cards , without setting IP...
2,222
Good Morning , I am working on a project with some PowerFlex 525 drives. I am using CompactLogix 1769-L18. I took notice that the tags that...
23
22,548
I am trying to commission a 480 vac PowerFlex 40 (22-COMM-E) in my home office ( I have 208 VAC hooked up to L1 and L2 . 120 VAC was not enough to...
2,495
Hello we have a PF70 with these connections 1 - Stop/CF 2 - Start 3 - Enable 7 & 8 - jumper 9 - 24 Vcd 14 & 15 Analog input sometimes (1 or...
5,293
