Powerflex 40
Alejandro01r
Jul 2020
DE/CAL/NV/NC
Hello guys,
Is there a way I could get the values shown on the parameter list to the PLC?
Currently the drives(powerflex40)s are connected by Device-net.
Using RSlogix500.
Thank you very much in advance.
Welcome to the PLCTalk forum community !
Because this is a PowerFlex 4-class drive, it lacks the very easy to use "DataLink" method to add feedback parameters to the I/O connection.
So you will have to use the HMI and a "passthru" driver, or use DeviceNet Explicit Messages in the SLC-500 program.
What model of SLC-5/0x controller are you using, and what firmware revision of the controller ? And what firmware revision is your 1747-SDN DeviceNet Scanner ?
Check your RSLogix 500 software and see if your controller program allows you to enter a DeviceNet Explicit Message (DEM) instruction. That will make explicit message programming much easier.
Your name rings a bell.... I think I have seen it before somewhere!
The controller is a 1747-L543C. Currently the device is using Mfiles. SDN version 6. But I m going to have to confirm tomorrow. Not at the office at the moment.
And its a negative on the DEM.
Thx very much for the quick response.
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
37
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
74
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
177
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
289
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
184
