Powerflex 40P-E / Controllogix communications
hobbes
Mar 2010
ny
I have a Controllogix PLC that I currently have communicating to a Powerflex 40P-E. I am able to set the speed of the drive without a problem but I would like to monitor some parameters in the drive but I don't know how to access them from the PLC. I have read the manual for the 22-COMM-E adapter and it talks about datalinks but I don't see how to set them up from RSLogix 5000. The screen shots they use in the manual don't match what I am seeing in RSLogix. Does anyone have more information that may help me? I have attached some screen shots showing the configuration screens in RSLogix.
Thanks,
tom.
The 20-COMM-E module, used with PowerFlex 7-series drives, supports "DataLinks", which are parameter pointers that are made part of the I/O connection data transfer.
The 22-COMM-E module, used with PowerFlex 4-series drives, does not support DataLinks. Any reference to DataLinks in the configuration will necessarily have a zero with it; in my opinion it shouldn't show up at all.
The only way to read and write parameters from the PowerFlex 40P drive over Ethernet is to perform individual parameter read and write actions using MSG instructions in the logic program.
Ken,
Thanks. I have added some MSG instructions to read the parameters I need. I agree, the configuration window is confusing since it shows 'Connection: Datalinks' even though they are not available for this drive.
tom.
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
247
I'm in the process of replacing an existing powerflex 40p. The old one died with no software backup but we did have a printout of the parameters...
1,214
How can I find the IP of a used Powerflex 40p? I have used them in the past I have a hand held programmer for the 22 Comm E that I used before...
1,773
Is there a way in rsnetworx or connected components to compare 2 powerflex parameter sets? TIA P.S this is also my first post here so hello...
2,239
I have P036 configured as 2 wire SRC Control with an exteranl supply. I choose the direction with a 3 point rotary switch. The problem is when it...
1,164
