Hi
the following I did with UnityProXL v4.1.
The syntax would be %I0.3.0:63 on the input pin of the copy_arebool_arebool block and %M500:63 on the output.
Unity might give you the following error "E1200 usage of directly represented array variables is disabled"
this can be enabled under variables of your project settings.
hope this helps.
